More top speed on sp twins
Ihave had problems with this 05 700efi, It will not run over 50mph, boggs for about 15 to 20 ft and then takes off. I love the machine but the dealer thats the best they can do. Ilove the new ride over the old ones. cant wait for spring to get here.
05 sp 700efi polaris
02 sp 500ho polaris
98 sp 500 polaris
04 kfx 400
04 ltz 250
02 sp 500ho polaris
98 sp 500 polaris
04 kfx 400
04 ltz 250
#15
BUBS, u got an 04 500 correct. U may try this. Go with a White Bros Can or Pure Polaris Can, get a WHITE Hot seat primary spring, or a Plain Polaris spring pn#7041021. Try 10/54 weights. leave the secondary alone for now. heres a small trick, when u get the cover off the clutch to change the spring, there is a nylon nut in there over the center shaft, take it out and shave 3/16 of an inch off the base end of it. This will allow the primary to close more on a full shift and attempt to send the clutches into an overdrive. If the atv runs well enough, it will make the power to full shift and get more top speed out of it.
AS for carberation, u may go down 2 sizes on the main jet, drop the needle dow 1 clip position, and if u got, get about 1 gallon of VP110 race fuel to 2 gallons supreme pump gas to make sure ur getting the full pull. ALSO the VP smells great. I run it in everything, even the lawnmower ha ha.............
youll have to feel it out and may have to get back to the weights and shave them to make sure the max rpm is proper to the atvs specs. good luck partner. HEY by the way, never be back of the pack.
#17
ok, get a WHIT E polaris spring PN#7041132 in the primary, got to 2 grams heavier weights and try that. IF it stays the same but seems to pull alot harder up to the 50 mph, then leave that in there and get a bit lighter secondary spring in it. I will investgate what to try for a lighter secondary spring tomorrow at work for ya and will let u know tomorrow. Try the primary work first and see. Good luck bud
#18
#19
Hey rmkcac700, I would like to try your clutch setup on my 02 sp700...I already have the white bros and k&n so I'll remove my airboxlid...now you say you did this on an 04.5 but I will need a different jetting setup because I have an 02, right??? Doesn't mine have different jetting than an 04.5?? Could you give me a jetting setup? main jet and needle position. Was that a 50/34 helix? silver primary and orange hot seat secondary and 10-58 weights? Also I'm a heavier rider, will it still work? Thanks so much, I've got a pesky neighbor with a new grizzly that beating me!![img]i/expressions/face-icon-small-frown.gif[/img]
