prime oil pump?
Old Mar 28, 2005 | 07:06 PM
fishing's Avatar
Default prime oil pump?
I changed the oil in my scrammy this weekend and also pulled the screen and cleaned it. After that when I started it the motor seemed to be alittle more noisy, do I prime the oil pump??
Old Mar 28, 2005 | 11:37 PM
fishslab's Avatar
Yes, if you cleaned the screen for the return in the oil tank, the oil pump must be primed.
Old Mar 29, 2005 | 12:46 PM
fishing's Avatar
How? sorry I'm a rookie.....
Old Mar 29, 2005 | 06:47 PM
fishslab's Avatar
Take a pair of needle nose pliers or something like it and pinch the hose going into the top of the oil tank. You want to pinch it about two or three inches from the tank. You will see a slit in the hose. You want your pliers to be on the motor side of this slit not the tank side. While pinched start the quad up a run it for about 30 seconds to a minute. Let go of the pliers and you should hear it relieve air with a swish sound like if you pressed the air valve on a tire. If you don't hear it repeat the steps. If you still don't hear it it may have self primed.
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
rockinkgin
Sep 25, 2015 01:52 PM
Sw00p
Sep 24, 2015 02:50 PM
