ANY IDEAS
Old Apr 30, 2005 | 11:02 PM
GORP's Avatar
Default ANY IDEAS
Heres whats happining i was riding my 04 500 ho in the yard after i did the oil change when i took a turn my keys got wedged and turned the quad off when i went to restart it it gave me a real hard time restarting ever since it won't idle to good i tried adjusting it and when i go to give it gas when i first start it it just dies kinda like a clogged fuel filte (i changed it so it has a new filter on it ) i also drained all the gas and filled it with new gas any ideas
Thanks
Old Apr 30, 2005 | 11:15 PM
SPORTSMAN70003's Avatar
Default ANY IDEAS
It could be your ETC on the throttle have you checked it?
Old Apr 30, 2005 | 11:50 PM
GORP's Avatar
Default ANY IDEAS
What is the etc and how do i check it
Thanks
Old May 1, 2005 | 08:45 AM
Default ANY IDEAS
Its the eletronic throttle control and tells if the throttle hangs open and if it does it will kill the atv. You should have a little slack in your cable if it don't you can adjust it down a few inches from the throttle control. Undo the boot in the cable and adjust it to have a little slack. You can also take the cover off the ETC and make sure the contacts are open if they are your ok.
Old May 1, 2005 | 10:12 AM
jimk72's Avatar
Default ANY IDEAS
Also so you know don't adjust your throttle until your engine has been warmed up for some time. I was having problems with my idle and My friend finaly told me that, so after it was good and warmed up I adjusted it to just the way I wanted it and its been fine every since.
Old May 1, 2005 | 10:51 AM
GORP's Avatar
Default ANY IDEAS
Ill give it a try thanks so all i have to do is check /adj the throttle cable
Old May 1, 2005 | 11:03 PM
Default ANY IDEAS
Yea it needs just a little slack.
fordfaithful21
Dec 7, 2015 05:52 PM
PrairieDog126
Sep 12, 2015 06:53 PM
Elkaholic
Sep 6, 2015 02:44 PM
toonces
Sep 5, 2015 01:14 PM
