SPAOTSMAN FRONT HUB
Old May 9, 2005 | 09:15 AM
Deerkiller's Avatar
Default SPAOTSMAN FRONT HUB
Nice job on the wheel spacer, We work primarily with aluminum and i had just what i needed in stock.
Thanks again,
Deerkiller
Old May 10, 2005 | 05:54 AM
oondaddy's Avatar
If your front hub is staying "engaged" it should be pulling on that side causing the quad to go the other way, right? The other front should be dragging slighlty. I had this problem before, turned out to be the brake caliper. If I were you, I would take the front brake calipers off, hang them up with a zip tie and see if you still have this problem. If you do still have it, then check out the hub assembly.
And I have never used a torque wrench putting these back together, I have always used the "snug it up and back it off a little rule" Never had a prob and the 4 wheel drive works great!! I do also suggest buying a repair manual, you can never learn too much about this stuff
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
