Rear wheel bearing play?
Hey how much play or slop should there be in the Rear wheel bearings on a sp700?
If I jack it up with my Crewline and grab the wheel/tire at the top and bottom, like you might do on a car, and push on it top to btm. it seams to have quite a bit of play back and forth.
This seams more than I would think is normal, both sides are about the same.
Jim
Jim
Hi I just went through this with my 2004 Sportsman. It would do the same thing checked the specs and with the dealer. I torqued them as spec'd @ 100lbs and there is still movement went and checked a new bike at the dealer it did the same thing I guess this is normal
my buddy has a 2004.5 500 sportsman and his drivers side rear wheel does the same thing. It is real bad, his dealer said it is normal though! My 00' isn't that bad, but his just came back from the dealer. He's buying a new bearing and we are putting it in as soon as he gets over his back surgery. It may be a few weeks but I'll let you know if the new bearing makes it any better.
My 04.5 500 did the same thing. I took it to the dealer and they told me the wheel bearings were shot. Had both sides replaced....265.00!!!!! Both of my rear tires would move back and forth. The dealer also told me he has seen it on sportsmans. It seems to be a common problem. Stay out of all water, mud, creeks ect., it will eat the bearings out fairly quick.
Noble
Noble
" just purchased a new K&N filter for my bike will I notice any difference,I see your running one "
2004 POLARIS 400 SP
I don't think you will notice any differance unless you get the power jet kit that comes with different jetting.
A freind with a 500 HO did say he noticed a big differance but i didint on my machine.
Jim
2004 POLARIS 400 SP
Jim
