Scrambler 400 Rear Brakes
Old 11-01-2005 | 01:06 PM
CED's Avatar
CED
Default Scrambler 400 Rear Brakes
Yep,i am still using the stock calipers,i can get you some pic's.
Old 11-01-2005 | 01:45 PM
scrammersam's Avatar
mine are stock and work fine, just need to adjust them once in a while
Old 11-01-2005 | 02:17 PM
conig's Avatar
I have been wanting to pull the front brakes off my scrambler for a while. I have to consitently adjust the drag I have beeld them , bought new bleeders and a new right caliper there are no holes in the lines and the fronts like to fail sometiimes they lock sometimes they don't.
from what I have been reading the non concentrics (Ced) do well without the front brakes and the concentrics can do well without the rear brake. being concentric this has concerned me some. I see people say removing the front prakes saves 10-12 pounds and removing the rear saves 10 pounds. wouldn;t there be more weight saving pulling the front brakes?
heres one of the posts regarding brake removal. ModQuads coments are all the way at the bottom.
http://forums.atvconnection.com/mess...eyword2=brakes
Old 11-01-2005 | 09:10 PM
rieds's Avatar
on my 98 i bought used somebody removed the brake line and rear master cylinder and put a plug in the caliper. seems to work great.
  #15
Old 11-01-2005 | 10:41 PM
Maddog419's Avatar
yea:
I think I got it down now. Thanks guys, I took a good look at the wife machs today. Compared to mine 4 machs (LOL).
The srambler rear pulger is off set. I see why it would get air in the lines now.
I think I'll put a wr250r set-up on it. 2004 set-up rear pulger.
The problem should be solved then.
Of cousre I"ll split the lines also. Before I add this set-up. Thanks all.
  #16
Old 11-02-2005 | 10:52 AM
conig's Avatar
reids do you mean they removed the foot pedal and plugged thast line or they removed the line from the hand brake.
STLyamwar
07-25-2020 04:44 AM
greg74
09-10-2019 03:03 PM
SixSpeed5
8
08-02-2015 05:38 PM
DeFox500
07-26-2015 06:32 PM
timster911
07-13-2015 01:57 PM
Quick Reply: Scrambler 400 Rear Brakes
