Is the Aaen clutch kit good?
Old Jun 8, 2005 | 09:40 AM
Spicollie's Avatar
Default Is the Aaen clutch kit good?
Is the Aaen Power Shift kit and a full Hpd Exhaust a good combo. Im looking for a clutch kit that will give the most torque?
Any suggestions Oh it will be on a 500 Scrambler
Old Jun 9, 2005 | 02:01 AM
XtremeSkier's Avatar
From what i have been told its not good to mix match manufacture'r brands when u use a pipe and clutch kit. For example if u get a HPD exhaust, get the HPD clutch kit, Aaen clutch kit/Aaen exhaust.
Old Jun 9, 2005 | 07:47 AM
ftwflh's Avatar
On a 4stroke the clutching isnt as important as on a 2stroke in matching to the pipe.You need to clutch your 4stroke to suit your style of ridding.Personally if your 500 isnt piped or anything I would run the Aaen blue secondary with either a polaris green or Dalton blk/white primary.
Old Jun 9, 2005 | 11:46 AM
Spicollie's Avatar
So if I got the Hpd pipe, the Aggresive clutch kit, and the Team Roller Secondary that would be a good match.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 9, 2005 | 07:12 PM
ftwflh's Avatar
I personally dont like the aggressive kit it engages too high and you loose some of your low end torque.I run a polaris yellow spring with a set of 10MB (50.5 grm) weights with a TEAM roller and my top rpms aree 5700-5750.And still have tons of lowend.
Old Jun 9, 2005 | 09:06 PM
Spicollie's Avatar
Thanks again
tmoose
Jun 30, 2015 08:28 AM
polaris scrambler00
Jun 20, 2015 08:49 AM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
neilbedwell
May 29, 2015 02:24 PM
