DARN KEY TURNS OFF IGNITION
Old Jul 3, 2005 | 08:15 PM
  #21
polarisbear500's Avatar
Default DARN KEY TURNS OFF IGNITION
yeah, mine seems to be getting better now, i grabbed the handlebars and pulled up as hard as i could a few times by standing on the floorboards and jerking the bars, it seems to have fixed it for now...pb500
Old Dec 27, 2007 | 08:59 PM
  #22
GPSATV's Avatar
I was having the same problem and it was the key chain, also check to make sure the battery posts are screwed tight, if the positive side is loose it will cause the engine to die.
Old Dec 27, 2007 | 09:38 PM
  #23
500DUSE's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: GPSATV
I was having the same problem and it was the key chain, also check to make sure the battery posts are screwed tight, if the positive side is loose it will cause the engine to die.</end quote></div>
Hello GPS,
Just letting you know this thread is 2 1/2 years old.
But yeah those key chains get alot of people
Old Dec 28, 2007 | 06:42 AM
  #24
it's never too late to help a fellow member.... i guess... however 2 1/2 years later is quite unusual. haha. thanks anyway-PB500
Old Dec 30, 2007 | 11:07 PM
  #25
BrandonsDad's Avatar
It seems as if the pod is bent. I had that problem but I had other keys on the ring with my wheelie key. Took them off and all is well.
Jmuddin284
Jan 19, 2026 07:16 AM
skinnyr6
Aug 25, 2023 02:18 AM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Unzzy66
Jul 11, 2015 10:01 PM
