What will give my 500 HO better throttle response & NOT void my warranty?
Old Jul 3, 2005 | 01:35 AM
Kevin108's Avatar
Default What will give my 500 HO better throttle response & NOT void my warranty?
I'm used to 400 2-strokes and the 500 is nice but to me it just doesn't quite have the instant power of the 2-strokes. I might be imagining this...but what mods would help throttle response and get the engine wound up quicker?
Old Jul 3, 2005 | 03:00 AM
polarisbob's Avatar
you could buy a clutch kit from heelclicker and it will have much better throttle response and it wont void your warranty
Old Jul 3, 2005 | 09:40 AM
jimk72's Avatar
I would start with a clutch kit(I like HPD), and then get a pipe and the HPD airbox mod. This includes the jet kit for the carb and does wonders for throttle response. As far as voiding your warranty you would have to check with your dealership. I just waited till mine was broke in and then added the mods. If something is going to go bad with the motor usualy it will be right away. If everything is fine after break in then just take good care of it with checking oil, gearcase fluid, trany fluid, ect.. before each ride. Unless you ride it almost every day than maybe once every other week.
Old Jul 3, 2005 | 10:23 AM
ftwflh's Avatar
If you want o keep your motor stock and not void your warrante get you a TEAM roller secondary and a white or green primary spring.The TEAM cuts all the resistance in your clutch where you dont loose any power and make shifts instant.
Old Jul 4, 2005 | 11:18 AM
Kevin108's Avatar
What's in the clutch kits and how difficult are they to install. (I'm mechanically inclined and have a garage full of Snap-On at my disposal. I can't rebuild automatic transmissions but I don't flinch about engine swaps.) What's in the TEAM roller?
Old Jul 4, 2005 | 11:38 AM
jimk72's Avatar
The stock secondary uses buttons and a helix that rides on them. Its basicly metal to metal for shifting in the secondary. A roller secondary uses rollers and a different shaped helix to shift very efficiently. As for installing them its very simple. there is instructions for a regular clutch kit in my pictures. If you get a team roller it comes assembled and you just have to replace the old secondary with the new one.
Old Jul 5, 2005 | 02:03 AM
Kevin108's Avatar
What do these two run?
COFatboy
May 2, 2020 12:06 AM
Nondem
Feb 22, 2020 12:20 PM
house1
Aug 9, 2015 10:49 PM
Roadglider09
1) Engine problems..
Jul 30, 2015 09:21 AM
Scottma518
Jul 10, 2015 12:42 AM
