500 sportsman poor power
sounds like you may have water getting sucked into the carb, check your airbox for water.
2nd- is your reverse override being pushed?
3rd- your reverse sensor may be bad- a way to check if the sensor is bad is go above 5 mph, and hit the reverse override button while in forward and if the engine spitting/sputtering clears up when you hit the button, the sensor on your tranny is prolly bad-also your reverse light is usually lit up while in forward when the sensor is bad
4th-maybe your camshaft is bad, causing it to idle fine, but when you gas on it in gear, it just doesn't have what it use too. hope this helps, PB500
The problem is a dirty air filter,that simple,not trying to sound like I know it all. But I own a 500 sportsman and the exact same thing happend to mine and all I did was put a new air filter in. By the way how deep of water do you ride in????Because I ride 4 and a half foot deep water every day and have helpful tips for deeper water travel !! [img]i/expressions/face-icon-small-wink.gif[/img]
bzdok1234
30
02-23-2016 01:55 PM
