Temperature gauge mounting
#21
tbg -
I purchased a temp gauge from jtatv, but have been having many problems with it, and can't get it to work. Did you have problems with your gauge, or did it work at first install?
Granted, the owner, Todd, is working with me to get it working, but it just won't work. Instead of splicing into my ignition line, I decided to run a direct line from my battery with a switch inbetween. To say the least, we've been working together for the past 8 months to get it working. I don't claim to be a rocket scientist, but I know my electrical lines aren't mixed up. Anyway, I think we've got the problem licked this time. The wire harness/connector is the problem I believe, or the wires aren't aligned correctly as they pass through the harness. Ugh! Very frustrating.......
I'm about to take the $80 hit, and try another route. Awfully expensive unit.....! The instructions aren't the best, and could use some refinement. Anyway, glad to see jtatv is working with me to get it fixed, or working.
