outlaw 500 release
Old Sep 19, 2005 | 03:46 PM
Webopper's Avatar
Default outlaw 500 release
Originally posted by: blazeman
...as I will be riding in varing altitudes 5000 FT. and above,
I just got back from a trip in the mountains with the Predator, stock except for a PP/White Brothers slip on, and didn't need to rejet or anything, and we were at over 9000ft. It seemed to get a bit boggy in the top end, but not a hugh difference. If I was staying at 9000ft, I would probably take a look at the plugs and see what they told me and maybe rejet from there, but performance wise, it didn't do too bad.
Old Sep 19, 2005 | 04:01 PM
NebraskaPower's Avatar
By going up into the mountains you basically make your bike run quite a bit richer that normal. Should notice that it is a little sluggish at the get go and also at the top end. the only other issue could be it may be running quite a bit lean back where you normally ride and then you wouldn't notice it as much. What is your normal alltitude you ride at?
Old Sep 19, 2005 | 04:48 PM
Webopper's Avatar
Between 1000 and 2000 feet. And hotter than he!! here in the desert.
Old Sep 19, 2005 | 05:17 PM
Have you ever had your bikes dyno tuned at that elevation? With going up 8K feet, you would need jets that put out about 20% less fuel to keep the perfect mixture. For every 1K feet it takes about a 2-3% change in jet size to keep it at optimum performance. As you go up, you take fuel away, because less oxygen and as you go down in elevation, you add fuel, more oxygen. Temperature has some to do with it as well. Colder air has more dense, so more oxygen. At my elevation (4K) I run a 165 jet with my set-up which makes it run like a raped-ape!!!!
Old Sep 19, 2005 | 05:55 PM
  #15
Webopper's Avatar
Nope, never had anything done like that (yet). I've only had it for about a month, so still sort of in the break in period. I'm thinking about taking it to a local guy here who is the chit with the Polaris (AZBADBOYZ) and saying here's $XXX, turn it into the beast I know it wants to be and seeing what he comes back with.
Most of the folks I ride with have drop in K&N and jetted at about 180. Not sure that's what will be right for me, and for right now I'm okay with her right where she's at. Soon though, very soon.
Old Sep 19, 2005 | 06:12 PM
  #16
Well, by doing the math and where mine is set now. That has to be really close!!!!
Falicon makes an awesome big bore/stroker kit - It makes it 600cc and flat mean!!! All you have to get is a bigger carb at that point. From visiting with them, it would double the horse power from stock. Cost on sending you parts in and having this done, including all there new parts is about $1900. A new carb is about $400 for a really good one and you would have labor on top of that. I am saving up $3000 to make it happen. This would make it the biggest, baddest, machine on the block!!!!!
The other mod is the longer +2" rear swing arm which is about $440 shipped in!!!!
http://www.faliconcranks.com/polatv.htm ----- That is the website for Falicon!!!!
Old Sep 19, 2005 | 06:17 PM
  #17
Webopper's Avatar
I am WAYYYYYYY to old for that much power. I ain't that deep into midlife crisis yet...LMAO.
Old Sep 19, 2005 | 06:47 PM
  #18
Can you imagine the power of a 100 horses on a 420lb bike?
You are never too old for more power!!! Take a look at your pics and double the air!!!
That would be having fun!!!!
Old Mar 15, 2007 | 09:00 PM
  #19
craw8101's Avatar
Where did you here about the efi on the outlaw coming out ??? gotta know cause im about to buy ill wait for that buy a 4x4 for now !
Old Mar 15, 2007 | 10:31 PM
  #20
spyder6's Avatar
talk about a thread revived from the dead
Sep 30, 2015 01:37 AM
BYC
Sep 25, 2015 02:10 PM
1000gade
Sep 9, 2015 03:35 PM
poutlaw525
Sep 9, 2015 03:19 AM
