Any tips on installing HPD chain tensioner?
Old Sep 10, 2005 | 09:21 PM
Kevin108's Avatar
Default Any tips on installing HPD chain tensioner?
No, I went to Puerto Penasco.
I'm not going to install that tensioner. It's not what I thought it was going to be. To eBay it goes!
Old May 15, 2009 | 10:03 AM
Kevin108's Avatar
4 years later, I actually installed this thing!
The first thing we did was to tighten the chain to an acceptable level.
Secured, prepped and ready for wrenching
We removed the wheel for easy access and we removed the stock chain guard as per the installation instructions
The stock tab cut easily and cleanly with a Sawzall
I retained the stock hardware just in case
I released the spring from the arm to ease test fitting
Still test fitting, checking the zirk clearance
Marked the holes
Measurements from the sprocket guard
Mine had a score mark that lined up with the bottom of the swing arm
Clearance from the bottom of the swing arm
Clearance between the chain and the zirk
Successfully installed!
And one of the first things I did after installation was get a small bamboo chute wedged between the nylon roller and the mounting bracket, which made it stop turning. I am going to destroy this piece in no time.
fordfaithful21
Dec 7, 2015 05:52 PM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
