Hard Shifter on SP500
Old Oct 8, 2005 | 11:47 PM
Elimin8r's Avatar
Default Hard Shifter on SP500
My '05 SP500HO shifting level is very hard to change gears. Is that normal? I mean I can get it into any gear I want but sometimes I have to really yank on it to do it.
It didnt really bother me until I looked at some Arctic Cat's last week and I could move the shifting lever through the gears with no effort.
IF this is normal does anyone know what I can do to make it shift easier?
Thanks
Old Oct 8, 2005 | 11:52 PM
tyler711's Avatar
Hard to tell without feeling it. I would say that yes, both my Sportsman's are hard to shift, but not bothersomely so.
Next time you're at the dealer have a walk around and check some on the lot, or try a friend's. My 05 is harder to shift than my 04, but that just may be from the 04's being more worn in.
Old Oct 9, 2005 | 11:50 AM
powerslider's Avatar
If it shifts harder with the engine running than it does without then there is a problem that should be corrected, usually it's a clutch alignment issue. My 800 was very hard to shift due to the alignment being off....
Old Oct 9, 2005 | 01:04 PM
Bionic's Avatar
same here . Eng alignment off, felt like the shifter would break rather than shift. It's been ok after another trip to the dealer.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Whitelx1
Oct 2, 2015 10:55 PM
exmotocrosser
Sep 26, 2015 08:18 AM
