2005 Sportsman Problem, Need help
Old Oct 16, 2005 | 07:32 PM
qdawg76's Avatar
Default 2005 Sportsman Problem, Need help
Ok, here is the Problem, When I am Riding my quad and I turn my Handlebars to the right all the way the enging sometimes shuts off, I cannot seem to find out why it does this, anyone else have similar problems? Any help is appreciated.
Old Oct 16, 2005 | 09:03 PM
powerslider's Avatar
The stuff hanging off your key hits the gas cap and shuts the quad off, use only the key (no chain)....
Old Oct 16, 2005 | 11:03 PM
elkbow's Avatar
yup, that is usually the problem....how much junk do you have on your keychain? take everything off but the key....
Old Oct 17, 2005 | 12:13 AM
Indyguy's Avatar
Mine has the same problem, scared me the first time it happened. Cleaning off the key chain fixed the problem.
Old Oct 17, 2005 | 01:15 AM
aklim69's Avatar
Same here. Killed the engine several times before I figured it out.
Old Oct 17, 2005 | 08:45 PM
JCDEYO25's Avatar
Same thing happened to me when I first bought mine. Now I just use the one key and I have a coiled keychain with a snap on one end connected to the handlebar just in case for some reason the key comes out. It's also a good idea to have a key cover which helps prevent dirt and water from getting in the ignition....
Old Oct 18, 2005 | 06:11 AM
SportsmanEE's Avatar
More than likely, this is a keychain issue, but if that doesn't fix it, check your ETC. It might be out of adjustment.
Old Oct 18, 2005 | 07:09 AM
Mudboss's Avatar
Man, I don't feel so stupid now that I know I not the only to do this
Old Oct 18, 2005 | 03:17 PM
Headsledracing's Avatar
pull a little slack out of the throttle cable from the pod and secure with a tie wrap to the handlebar,it was the throttle over ride(ETC) kicking mine out with the hard right hand turn.No key chain on my bike
Steve
Old Oct 18, 2005 | 03:22 PM
qdawg76's Avatar
Thanks for the input everyone, I know it isnt the key cause I had already corrected that problem after I had ridden the quad for the first week. I think it is the throttle cable. I will give that a try. Thanks
neilbedwell
Nov 10, 2018 11:02 AM
Land_shark1
Jul 10, 2015 12:53 AM
Marc Parish
Jun 26, 2015 09:37 AM
hoopduerr
Jun 1, 2015 08:22 PM
May 27, 2015 11:15 AM
