Glacier plow on a 04.5 sportsman 500
Has anyone put this system on this machine because I'm not seeing how the plate will mount up. I can't see where the middle brackets mount to the frame. The instructions say to remove the two lower bolts on each side of the brush guard to frame, I'm not seeing these bolts on mine. My buddy put one on a 700 and I was wondering if the frames are different between the two machines.
Yeah, I have the same plow on the same bike. Your kit should have come with a small bar that goes over top the frame. This bar bolts to the plow mount with the two provided bolts and nuts. I had the same confusion when I did mine. Remove no bolts, it just clamps to the frame. Happy plowing!!
