Side lever on a sportsman?
Old Dec 15, 2005 | 05:33 PM
2brokenlegs's Avatar
Default Side lever on a sportsman?
Has anyone else had a problem with the gear selector on a sportsman? I can't seam to figure out why this is giving me troubles. Are there any good places to get used parts?
Old Dec 15, 2005 | 05:43 PM
mtpockets's Avatar
WAY more info needed!
what kind of trouble?
what year and size Sportsman?
why do you need parts?
what kind of part are you looking for?
Old Dec 16, 2005 | 09:47 AM
Sorry about the vaugeness, It is a 2000 335 sportsman. And the gearselector, you know
high low reverse deal on the right side. When i bought it I noticed it would stick in low
when i tried to put it in reverse, then when I put the polw on and tried to use
4 wheel drive it would not engage unless i applied forward pressure to the gear lever.
Is their any kind of adjustment on that thing? I adjusted the links to the trans, but ended up
undoing the adjustment I made cause it would not hit rev, or forward. The guy at polaris
said to not try taking it apart, he did and had to have someone else fix it. This year it wont
engage 4 at all, it did grab in reverse once but thats it. The gear sel. lever mechenism
from polaris is 290.00 dollars, is their any used parts online that you know of? Do you think it
might be something else? I changed hub and front diff juice, didnt fix any. Thank you
for your help..
Jmuddin284
Jan 19, 2026 07:16 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
