Scrambler has a mind of it's own. Please help!
Old Dec 20, 2005 | 01:11 AM
YEA's Avatar
YEA
Default Scrambler has a mind of it's own. Please help!
My scrambler will start one minute just fine but then if i shut it off it may not start again. It cranks over but has no spark. It was running kind of rough before this happen the first time. Any input on what may cause this would be appreciated. Could it be the CDI?
Old Dec 20, 2005 | 02:28 AM
jimmypsp700's Avatar
Maybe gas lines plugged or tank venting???
Jim
Old Dec 20, 2005 | 02:30 AM
IdahoVinnie's Avatar
Jim
He said "no spark".
Old Dec 20, 2005 | 02:59 AM
Jim
He said "no spark".
Well? Then whats your reply to the no spark?
What should he do?
Jim
Old Dec 20, 2005 | 03:15 AM
Jim
He said "no spark".
What should he do?
Jim
Hey Jim, I meant no disrespect. I just couldn't see the connection.
I would start with a testlight at the ignition switch. When it won't start, check for voltage TO the switch. No power=problem between switch and battery. If OK, check for voltage on the far side of the switch (wire going to cdi). No power=bad ignition switch. If OK, check same wire at cdi. No power= open in wiring harness. If OK, cdi needs to be tested.
Old Dec 20, 2005 | 11:59 AM
scrammy01's Avatar
I had a problem with my key switch. It seemed like condensation so I sprayed some ignition sealant on the back side and the wires and haven't had any problems since. Don't know if it will help but maybe.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
Minimod
Sep 10, 2015 09:20 PM
