Trail Boss Stalls When Put In Reverse
Old Dec 26, 2005 | 04:49 PM
zappa24's Avatar
Default Trail Boss Stalls When Put In Reverse
When I put my sons 93 Trail Boss in reverse it stalls. I figure it is the reverse light switch but I'm not sure where to look for the short. Any help would be great.
Old Dec 26, 2005 | 06:44 PM
ftwflh's Avatar
It is your reverse limiter box.It will be the box with 3 wire just follow the black one to the wire bllock and unplug it.
Old Dec 26, 2005 | 07:01 PM
zappa24's Avatar
Is this box located under the dash?
Old Dec 26, 2005 | 07:28 PM
ftwflh's Avatar
I am not sure on the location but it is the box with 3 wires the other box is the voltage regulator.
On a 400 Sportsman it is on the frame by the oil tank.
Old Dec 26, 2005 | 10:41 PM
textrout's Avatar
Agreed, the Reverse Limiter. It is not a hard fix at all, if you can get the part. I fixed mine 93 trailboss with this problem by getting a good used switch. I think I found mine on e-bay for $15.00. Fixed it right up.
Good luck with keeping her running.... I'm always having to fix something!
textrout
Backwoods_badass
Aug 2, 2015 10:40 PM
Backwoods_badass
Aug 1, 2015 10:25 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Gnuters
Jul 19, 2015 10:03 AM
