Predator Stalling
Old Dec 31, 2005 | 03:58 PM
Daranello75's Avatar
Default Predator Stalling
My Predator will idle fine, but when im riding and get OFF the gas to go back to idle it stalls. By the way its cold outside
Old Dec 31, 2005 | 07:00 PM
rfwlll's Avatar
I know it's a job but check your plug to see if your running lean. About a month ago when I was riding my pred in the cold, well around 35-40deg, my pred would choke every once in awhile and pop a little, but I think it was due to the cold as it was a little harder to start as well. Well it did'nt really start hard, I just had to use the choke and let it run for a few before taking off, which I usually let it run a little anyways before taking off. Let us know what you find. If it is just running lean, adjust your needle up a notch and see if that helps. Well good luck. RUSS
Old Jan 1, 2006 | 01:58 AM
Will just pulling out the chock a tad work? And BTW does your fan run long after you turn off the motor?
Pehter
Oct 3, 2024 11:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
