Vision wheels
Old Jan 6, 2006 | 06:26 PM
Polaris2004700's Avatar
Default Vision wheels
I was thinking of getting a set of the Vision wheels with the imitation bead locks to put on my 2004 700. Are they the same width as my factory chrome rims? I tried to find the rim width in the owners manual but couldn't find it.
Old Jan 6, 2006 | 07:20 PM
powerslider's Avatar
Front are 6" wide and the back are 8" wide, getting them balanced if needed may be a problem with the wheels not having a center hole but it can be done with the right equipment. I don't know if any dealers have balancers for these wheels, mine doesn't...
Old Jan 6, 2006 | 07:59 PM
I was told by the seller that the Visions are 7" fronts, will stock tires still fit on these if mine are only 6" now?
Old Jan 6, 2006 | 08:06 PM
Yes they will fit, I was referring to the Polaris wheels like on the 800. Can you get 8" rears? Many aftermarket wheels use 7" front and rear but I prefer the stock widths. 7" is a bit narrow on the rear for a 11" wide tire but they will work...
Old Jan 6, 2006 | 08:21 PM
Yea the seller says he has 7" fronts and 8" rears.
Old Jan 6, 2006 | 08:30 PM
Your set then, go for it.....
Old Jan 11, 2006 | 09:56 PM
So the Vision wheels are solid across the middle of the wheel? I assumed they just had a center cap like a car wheel might have?
Old Jan 11, 2006 | 10:01 PM
The OEM Polaris wheels are solid, no center cap...
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
