clutch weights all the same
Old Jan 6, 2006 | 09:39 PM
VAP1507's Avatar
Default clutch weights all the same
My dealer told me that the 600,700,800 clutch weight are not the same as all the other atv or sleds is this true? I would like to get some weight and play around with my clutching.
Old Jan 6, 2006 | 10:20 PM
SPORTSMAN70003's Avatar
Yea they are all different weights. The 800 uses the heaviest I think 60 & 62 grams and my 700 had 56 gram weights stock. The 600 use lighter weights than 700 but I not for sure what gram.
Old Jan 7, 2006 | 12:23 AM
VAP1507's Avatar
The same the dealer is telling me that 600,700,800 weight are not the same style as the other atvs and seld. I have a freind with a lot of sled weights and the dealer tells me they won't fit is this true?
Old Jan 7, 2006 | 02:22 AM
MaineMudder3's Avatar
Sled and atv weights are in fact different and will not work!
Old Jan 7, 2006 | 07:50 AM
ftwflh's Avatar
Some will and some wont .The bushed(ones with bushings) sled weights will work.
Heck just get some of your buddys sled weights and take the ones out of your atv and compare.Bet they will interchange.
Old Jan 7, 2006 | 09:23 AM
Andre's Avatar
Vap I see you already have the EPI clutch set-up, however the Heel Clicker clutch kit will allow you to play around with clutch weights by adding or subtracting the weight and location on the weight arm. At around $160 it's an inexpensive way to experiment with different weight and primary spring combinations.
buddieboy
Dec 9, 2016 05:50 PM
Robinhood
Dec 26, 2015 10:28 AM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
