Scrambler 2wd: Tire recommendations
Originally posted by: gunman457
A Douglas salesman told me that when I called them for a part number. And he did have a little problem finding the part number because the rear rims have the same bolt pattern as a golf cart.
I am taking this from memory but I believe my KFX has 22x7x10s and the scrammy 23x7x10 all I lose is 1 in in height. Am I missing something here? They are both 7x10 rims the 22s should fit.
A simple solution for the rear rims on a Scrambler is find a used set of Predator hubs with the 4/110 pattern and you will have unlimited amount of rims. To even make it better you can put 400ex hubs on your V-force and switch between both quads.
#15
#16
Hey GE4x4
I see what your saying. You can change the tires back and forth without changing the rims by having different hubs. Cool. Can you also change them with a golf cart?[img]i/expressions/face-icon-small-happy.gif[/img]
#19
GE4x4, Good point on the wheel package. May have to keep an eye out for honda hubs. Thanks for the V-Force service manual BTW. Will help me alot even though you can blow my doors off now with the Raptor 700!!!!!
