Bent CV Joint??
Old Jan 12, 2006 | 09:12 AM
Bytor's Avatar
Default Bent CV Joint??
I have a 2004 SP400 and just replaced my left front hub inner seal which was leaking. After putting everything back together, had the quad on a lift to check 2wd/4wd operation, and in 2wd, the left tire was wobbling. I assume that the CV joint is bent because the drive shaft looked okay. I did take a hit pretty hard on the left side which bent the A-Arm. I replaced the A-Arm but didn't notice any other damage at the time. Does my assumption sound correct? I haven't had time to tear the whole thing apart yet (I noticed this at about 11:00 last night), was wondering if others have seen this.
Thanks.
Old Jan 12, 2006 | 09:18 AM
PatHayes's Avatar
bent wheel.
Old Jan 12, 2006 | 10:44 AM
cornbread2's Avatar
It would be almost impossible to bend a CV joint.
Old Jan 13, 2006 | 09:20 AM
Bytor's Avatar
Tore everything apart last night. Drive shaft is bent. Oh well, what's $300.
Old Jan 13, 2006 | 09:22 AM
PatHayes's Avatar
OUCH!
Old Jan 13, 2006 | 10:04 AM
cornbread2's Avatar
Don't spend $300 yet.
Take it to a maching shop or a local garage and put it in a press.
I have fixed many rear axles by bending them back into shape in a press.
Albertaboyy
Sep 9, 2015 09:51 AM
meddy0388
Sep 9, 2015 06:41 AM
89Lt250r
Sep 7, 2015 07:53 PM
toonces
Aug 13, 2015 12:40 PM
metal249
Jul 28, 2015 09:35 AM
