scrambler 400 top end rpm
Old 11-08-2000, 06:11 PM
scramblered's Avatar
did you known read,i've BORED MY CYLINDER TO .080(20CC INCREASE) there is my additional hp man!
Old 11-08-2000, 09:31 PM
A400L's Avatar
Look retard, an .080 bore WILL NOT give you 10HP! A HPD big bore 440 kit wil not even produce that amount of power. Approxiamtely 80% of the HP you pick up by increasing your displacement is on the bottom end. So out of the 10 you think you have you might have 2!
Think about it, $95 for a .080 piston, and $50 for someone to do the bore is $145. That indicates that you are getting 1HP per every $14.50 spent. That is absurd considering with a pipe the return is approximately 1HP per every $25.50 spent (HPD trail). Theoretically a HPD race mod set up costs $17.50 per every 1HP gained (30HP over stock according to HPD).
According to those equasions boring is the cheapest way to increase HP. So why haven't I bored my cylinder to .080 over? Because in reality the cost does not justify the performance gains!
Quite taking your bike to "Pierre's snowblower repair shop" and try calling HPD or RCR and talk to someone who knows about Polaris motors.
Guess what, next time you seize a piston and need to have the cylinder bored, a new piston (86.5mm) will cost you $145! One more after that you'll have to buy a new sleeve for $400, while I'll be on a .020 over and roosting you butt.
Old 11-08-2000, 10:07 PM
j'men caliss pas mal moé du rapport gain versus montant,j'ai deja un 88mm dans mon scrambler pis j'ai ai changé mes sleeve pis mon scrambler y produit 75hp!moé mon cylindre ya été fabriqué sur mesure pis y marche pas mal plus que ton tit 400 stock!si tu pense quand fesant borer ton cylindre tu gagne seulement 1 hp man tu sait pas de quoi tu parle.pis j'en ai mon voyage te t'expliquer comment faire marcher un scrambler 400!
kick *** scrambler with 75 hp!
Old 11-08-2000, 10:16 PM
QuadBuster's Avatar
OK!
Looks like you are scared to let people who dont comprehend your language know what the he!! you just said.
I quite believing every thing that come out of your mouth when you said "I got my crankshaft ported"
I am now 15% stupider b/c of you!
EC
P.S. What was the point of this topic to begin w/.
  #15
Old 11-09-2000, 12:26 AM
ok,excuse my word i was trying to say'crankcase porting'instead of crankshaft porting,the rest of my tale is absolute true,i did that on my xcr 800!
  #16
Old 11-09-2000, 12:38 AM
A400L's Avatar
Now explain to us how you port a crankcase?
Rick, I think I've identified the guy who keeps calling you with those diagnostic problems!!!!!
  #17
Old 11-09-2000, 12:45 AM
WIscrambler's Avatar
Scramblered~
Why don't you just admit you're wrong because the $hit you're talking is getting way too deep! A400L was right about your boring job. And fom reading other posts he has made, he sure the he!! knows what he's talking about! What was the point of your first post? If your engine makes the most power at 6500-6700 rpm's, why the he!! are you revving it out to 7200 rpm's!??!? Hey...I think some guys were talking about you in Rick Ritter's latest post..."crazy problems diagnosed". You seem like just the guy that would ask all those stupid questions! HAHA!! Here's a few tips for you...
1. Make your questions clear when you start a new post.
2. If you're going to be telling some BS, at least make it believable.
3. Most importantly, don't pi$$ on an electric fence!
  #18
Old 11-09-2000, 12:56 AM
Scramblered~
Really, you ported your crankcase!?! You'll have to show me how that was done. It must be worth a good extra 10 hp. Are you sure you didn't mean to say 85 hp!?! Oh, I ported the crankshaft on my thundercat...it makes a good 200 hp just from that alone! Your XCR must be making a good 180 hp now, right? *cough* bull$hit *cough*
  #19
Old 11-09-2000, 12:58 AM
onne more thing, I just can't resist...that roller clutch must have gave you a good 5 extra horses too, right?
  #20
Old 11-09-2000, 02:11 AM
Dazed's Avatar
Hey guys cut him some slack. Yes you can port a crank case it is very easy to do. Just take a 1/2" drill bit and put some holes in it and that way watter wont stay in there and you wont have plant life growing in you cylinder.
Quick Reply: scrambler 400 top end rpm
