05 500 HO Body Plastic
Has anyone notice your rear body tabs pulling apart from the top section of the frame where the push pins hold the plastic?? The first tab at the forward section is a single hole for no movement to be allowed why the the other two have a slit for fitting the push pin as needed. Well the fix positon tabs on my HO are ripping apart. If one takes a good look on how the body is supporting the composite rack weight the body gives with the rack when loaded with cargo. Over time and rough trail riding the possibility is there for the rear fender body to start to weaken and tear loose. Plus the side panels won't fit snug as new either. So, All the 05 model owner keep a look out!
Mac The Red Rhino
05 500 HO
Mac The Red Rhino
05 500 HO
Customer Service #1
05-15-2020 08:46 AM
Quadzilla Heritage
09-25-2015 01:39 PM
