great service!
Had a big problem with my pred in that it just would not run the way I thought it should after cam was placed in it. It was faster and everything but still I could not figure out how I could barely beat the 450s out there. I took it to Bad Boyz in Glendale,Az. and I spoke to Dennis Shotwell, he only works on polaris products and figures out what is needed. Turned out my cam was off one tooth and I also had him install a Pro Flow filter and outwear which is bolted onto the airbox! I can not keep it down!!!So much power that I now have to figure out how to keep it down and it is faster than I thought it could be. He suggested that after I play with it awhile that he will do some carb work that is increase horsepower as well as throttle response. Again service was tops and the price was reasonable. His name again is Dennis Shotwell----7012 N. 56th ave.---Glendale, AZ 85301---602-696-5875---www.azbadboyz.com
You can not go wrong.
It was installed wrong, he also helped me by contacting that shop and stating what was wrong, he was able to get the cost of fixing my cam back!! Two hours worth is what it took to correct it, both shops have a good customer relationship and both will do what it takes to make a customer happy as long as its their fault. Great folks uh!
bpegram84
07-22-2015 08:15 AM
