scrambler clutch application ?
Old Feb 23, 2006 | 11:52 PM
brownmecha's Avatar
Default scrambler clutch application ?
Can anyone tell me if a 95 scrambler 400 drive clutch will work on a 98 scrambler 500?
Old Feb 24, 2006 | 05:34 AM
jimmypsp700's Avatar
I think it should, the only two used were EBS and non EBS with diff components (spring, weights).
It may need some fine tuning and aligning.
Jim
Old Feb 24, 2006 | 05:38 AM
Check Polaris parts manuals online or at Ronnies for cross ref to other years.
Jim
http://parts.polarisind.com/Browse/Browse.asp
Polaris OEM parts search microfiche
http://www.polarisoemparts.com/index.php
parts by number / search microfiche
http://www.discounthondaparts.com/
http://www.ronnies.com
Ronnies
http://www.ronnies.com/store/page244.html
Ronnies Polaris
http://216.37.204.202/polaris_oem/Po...?Type=12&A=149
Ronnies Polaris 2000 Scr 400 Microfiche
Old Feb 24, 2006 | 07:57 AM
ftwflh's Avatar
They will interchange but you may want to use the weights out of the 500 and the spring out of the 400.500 weights are lighter and a differant grind.
Old Feb 24, 2006 | 07:11 PM
brownmecha's Avatar
Hi again ftwflh, this isn't the first time you helped me. I allready ordered some springs that Rick Ritter suggested for my 500 clutch. When I tore it down to change them I noticed the buttons on the spider were missing and grooved the contact points up a bit. Sooo I'm looking into a used clutch in better shape. If I purchase this 400 clutch, I understand I should use my 500 weights, but what about the springs I just purchased for my 500 clutch? Are they still the right ones, or do I need to re-order 400 springs, setup for a 500 scrambler?
Old Feb 24, 2006 | 09:45 PM
ftwflh's Avatar
The springs Rick gets you will work great.But do use the 500 weights .The 400 clutch comes with a white spring that is a good all around spring for any stock polaris.
fordfaithful21
Dec 7, 2015 05:52 PM
Minimod
Sep 10, 2015 09:20 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
