problem with 4x4 on 04 700
Old Mar 7, 2006 | 07:54 PM
ktmmad's Avatar
Default problem with 4x4 on 04 700
HI, I'm new to this foram. I have a problem with the 4x4 engaging when the switch is in the off position. I had broke the speedo the first day I got it home and when I pulled the wires off the back it hade no all-wheel at all. So I put a new speedo on it and it worked great on the dirt, but first snow I wiped it around a turn and it slamed into all-wheel and sent me in the woods. I took it to the dealer I got it from and he told me its going to do that if the back wheels slip to much no matter what the switch is set for. Is that true. I love my toy, but I need it to be 2 wheel drive unless I need the 4 wheel. Any help would be great
Old Mar 8, 2006 | 06:46 PM
ktmmad's Avatar
Any help out there?
Old Mar 8, 2006 | 07:57 PM
MNATV's Avatar
When you replaced the speedo did you replace with the same year as your ATV? I know that if you use a newer gauge (one with fuel gauge in it) and you have an early o4 model or newer the 4wd won't work correctly.
Old Mar 8, 2006 | 08:34 PM
ktmmad's Avatar
yes, the old one had the fuel gauge on it and the one I replaced it with does too.
Old Mar 9, 2006 | 02:21 AM
sportsman2004's Avatar
A buddy of mine was having the same problem. The polaris dealers kept feeding him full of bull. Finally they ended up replacing the front diff and has not had any issues since then. Most of the time, it is a cracked hillard or fluid issues. I had mine get water in there and it caused it to engage. A new seal, correct fluid levels and no issues since then.
Old Mar 9, 2006 | 09:18 AM
Kerbbirds's Avatar
It should not do this, the dealer is full of it.Seems alot of machines are having this problem, polaris should address this.Do a search on AWD and se all the posts about it.
Old Mar 9, 2006 | 07:55 PM
ktmmad's Avatar
Thanks, thats what I told the dealer. Why would Polaris put a switch if it was going to go into AWD when it wants anyway! I'll check the AWD post thanks.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
