400 Scramber coolant/engine/fan problems
Old Mar 19, 2006 | 06:31 PM
chevyboy400's Avatar
Default 400 Scramber coolant/engine/fan problems
Ok, heres the scoop. My 400 scrambler's fan is not turning on when it should. The engine overheat light turns on and the fan doesn't turn on. Another thing is there is coolant leaking out of my exhaust pipe and is spraying out of the red blowoff cap on the overflow can, the thing on the left side towards the front, its blue colored. When i open the radiator cap the coolant is really foamy and seeps out the top with the cap off. Just wondering what is going on with it, it starts and runs fine, but started recently doing this and havent ridden it since. Any input would be greatly appreciated. Thanks
Old Mar 19, 2006 | 07:53 PM
LittleBill's Avatar
sounds like a head gasket is gone, if you have coolant out the exahust
Old Mar 19, 2006 | 10:07 PM
Hoopie's Avatar
definetly sounds like a head gasget. Drain the coolant and change the gasket and fill her back up and you should be fine. While your at it you check your compression after the head gasket replacement.
Old Mar 20, 2006 | 12:18 AM
handycap's Avatar
Head gasket bad,
fan and or fan switch bad.
Old Mar 20, 2006 | 01:02 AM
I tripped the fan wire and the fan works, what i am thinking is the head gasket is bad, causing the coolant to do everything it is doing. The head is not cooling down because there is a bad seal so the engine temp light is turning on, but the engine itself is not hot enough for the fan to turn on yet. Its 30 degrees here and snowing, i was riding it earlier, so the rest of the engine is cooling. Ill call my dealer tomorrow and see if I can get a gasket. 20" of snow expected by tuesday morning, so I have to get it running. Thanks for all the help. Any other suggestions are welcome. Thanks
Old Mar 20, 2006 | 02:07 AM
scrammersam's Avatar
i was having pretty much the same thing happening and all i needed to do was top the rad off with water so that it was right full. im not sure about the leaking out the pipe, but i did have coolent sprayed everywhere
Old Mar 20, 2006 | 03:03 AM
magnumLover's Avatar
if there is foam in there man
you got water in your engine [img]i/expressions/face-icon-small-sad.gif[/img]
Old Mar 20, 2006 | 09:33 AM
Hoopie's Avatar
another suggestion after replacing the gasket is to get some SeaFoam and put it in the oil following the directions on the can to get rid of the remaining water in the engine if there is any.
Old Mar 20, 2006 | 10:48 AM
WIscrambler's Avatar
make sure your bleeder screw on top of the head is tight. That could make coolant drip onto the exhaust also.
Old Mar 23, 2006 | 09:01 PM
Bleeder screw is tight, it looks like the area around the cylinder base gasket is wet, could this gasket possibly be the one that is bad? Thanks.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
