winch problem
Old Mar 20, 2006 | 12:33 AM
magnumLover's Avatar
Default winch problem
i have a 2000ib worn winch
i currenty took out my atv and tryed the winch and the thing is totaly backwards
when i press in it goes out ect
when the wire gets out about half way the out is out again ect.
there is a big rats nest in side the winch and i was just wondering if there is a simple way of fixing this without taking it all apart.(the winch has a stell plate covering it)
thanks
Simon
Old Mar 20, 2006 | 01:01 AM
IdahoVinnie's Avatar
Without going into a lot of detail, it sounds like the rats nest is your problem. Hook the cable to somethins that won't move (car, tree, etc). Place the winch in the freewheel position. Start the atv and put it into reverse to try to undo the rats nest. It may not be easy. Good luck.
Old Mar 20, 2006 | 01:18 AM
what is the freewheel position?
Old Mar 20, 2006 | 01:49 AM
On one end of the winch, the electrical wires are attached. On the opposite end is a rotating "****" which when rotated, will disengage the winch spool from the winch motor (puts it into neutral). This allows the cable to be freely pulled out, without using the switch.
Old Mar 20, 2006 | 02:05 AM
thanks alot man i hope i can get this all worked out
Old Mar 20, 2006 | 02:07 AM
and man
IS YOUR ATV STREET LEGALL????????
Old Mar 20, 2006 | 04:07 AM
lol
Old Mar 20, 2006 | 04:37 AM
Sure is. I can ride right through town to get to the trails. Or a quick run to the local 7-11 store.
toonces
Oct 19, 2015 02:21 AM
user493
Aug 13, 2015 12:54 PM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
