White spring
Old Apr 5, 2006 | 01:43 AM
smatpak's Avatar
Default White spring
How hard is it to change the spring? i read that is all you have to do to get more low end.is this true. also i see so many people poppin wheelies in high gear. i can t get mine to come up in high just low. don t get me wrong i don t want to do wheelis i just want that type of power.03 sportsman 500ho
Old Apr 5, 2006 | 02:39 AM
jimmypsp700's Avatar
The primary spring is easy to change out, i have the HSP green in mine (sp700) and it will wheelie easily in low but not high.
Jim
Old Apr 5, 2006 | 08:25 AM
scootergptx's Avatar
Supersock
Hired Gun!
Didn't like the white as much as the EPI pink. White engaged too high. If I was in sand, it would spin the tires and dig a hole. Pink spring has a little lower engagement, and has more top end.
Old Apr 5, 2006 | 08:40 AM
MYWAYOUT's Avatar
Had the white also.... Hated it.... RRRR's were too high before engagement....
Removed and returned to stock...
Old Apr 5, 2006 | 12:08 PM
Redhans's Avatar
I have the white primary in mine and it was pretty easy to change. Just make sure you torque the bolts properly when reinstalling them. I don't notice the low-end as much in high but I do notice I have more low-end in low. There is a higher engagment too then with the stock spring.
Old Apr 5, 2006 | 05:20 PM
crashby's Avatar
i put the white spring in my bike and love it
Old Apr 5, 2006 | 08:39 PM
Backinthesaddleagain's Avatar
I have not tried the white spring. But I am running the EPI pink and it does make a nice improvement over the stock spring.... lets you operate at slow speeds and from a dead stop a little higher into the powerband of the motor. Nice all-around spring. I am curious, however, about trying the Polaris white.
Old Apr 5, 2006 | 10:07 PM
8675309's Avatar
I had a Green Polaris spring intalled in my 05 500 HO, it engages a little higher but now I can pop a wheelie with no problem in Low, and I can pop a wheelie in Hi when I kneel on the back of the seat so there is more weight on the back and pull up on the handle bars. It impressed me!
Pehter
Oct 3, 2024 11:00 PM
salixair
Nov 3, 2015 08:25 AM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
