Replacing belt right now need help!!!!!
Old Apr 7, 2006 | 06:34 PM
4x4marvo's Avatar
Default Replacing belt right now need help!!!!!
I bought a new belt for my 02 700 sportsman and when i got the belt cover off it looks like the belt that is on it is in good shape. We had some snow a few weeks back and the belt would scream alot so i decided to replace it now and it looks like the belt is ok, what do i do? Do belts stretch? could that be what is wrong with it? Also how do i take the belt off and put the new one on? Do i pull the big clutch looking thing off? PLEASE HELP I AM WORKING NOW[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 7, 2006 | 06:43 PM
4x4marvo's Avatar
HELP!
Old Apr 7, 2006 | 06:46 PM
upnort's Avatar
It dont take a whole lot of wear to lose pep. Wont hurt to put the new one on. To loosen & get off have to push & I believe twist the outer sheave on the secondary (rear ) It is very stiff so you have to do it hard. Then your belt will fall down into the wider opening between & you hold & pull belt out. Install in opposite.
Old Apr 7, 2006 | 06:48 PM
4x4marvo's Avatar
so i dont take the front clutch thing off?
Old Apr 7, 2006 | 07:02 PM
yaK's Avatar
yaK
you should not have to take anything except the outter cover off to get the belt off...do a search on here for complete details...
Old Apr 7, 2006 | 08:38 PM
4x4marvo's Avatar
ok belt is on and it is worse? i took the old one off and slipped the new one on pretty easy, does this mean my clutch is bad? I took my air compresser and blew all the dust out of the clutch housing, any idea what i do next?
Old Apr 7, 2006 | 08:42 PM
Viper65's Avatar
Hey 4x4 marvo... You may be looking for a link like this? Belt replacement
Send a 12 pack of beer to the Following address....... [img]i/expressions/face-icon-small-happy.gif[/img]
[img]i/expressions/face-icon-small-wink.gif[/img]
Hope it helps you.. Complete with pictures and a guide...
Old Apr 7, 2006 | 09:24 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you changed the belt out and you said its worse? how is it worse, what is it doing?
Old Apr 7, 2006 | 09:40 PM
4x4marvo's Avatar
It barely pulls like it is slipping and when i stop and took off in high it squealed little bit. I tried to pull the clutch housing off with a 3 hook wheel puller but i didnt crank it hard i tried to pull it off and it didnt seem to wanna come so i stopped. then i just worked the belt on with my hands, i did turn the pulleys backwards would that hurt anything?
Old Apr 7, 2006 | 09:50 PM
la90043's Avatar
you need to adjust the belt tension
