Speedo problems
Old Jul 2, 2006 | 06:04 PM
bjrjr16's Avatar
Default Speedo problems
I replaced both my wheel sensor and cable and still nothing worked.
Old Jul 2, 2006 | 07:10 PM
wayout's Avatar
you also have a circuit breaker under your front rack,under your center plastic where your radiator is,it's inside a sealed black plastic sleeve,run your power wires into it,to make sure you have the right one,cut it open and check every thing in their,this might help..wayout,out................
bk18's Avatar
Glad I found this post.. My speedo has not worked for some time either.. Never experianced the bounce, just stopped working one day..
OK now to the important issue.. I was on a few hour ride the other day.. Thankfully toward the end of the day my electronic dash (RPM, Milage,ect) would die out and then come back.. Sometimes die out(shut off) for 20-30 seconds, sometime 2 seconds.. Then it would work again for a few min, then die out again.. Any ideas on this one? No deep water but plenty of mud and shallow water..
Even more important when that dash goes out do you think I am loosing 4WD as well.. I though about stopping and testing it on the ride but that I figured I just better keep goinging and get it back to the trailer.. Is it possibly the two electrical posts/connections next to the battery shorting or something.. Thanks guys
Old Jul 4, 2006 | 11:47 PM
BdweiserRacing8's Avatar
Not sure bk18, but if your electrical appliances are kicking in and out, your 4WD will do the same also, When my battery died, i had to pull start, and the 4WD would not work cuz its electrical.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
