Anyone Having Problems with Hawkeye 300
Old Jan 14, 2007 | 09:10 PM
  #71
ranchrocket's Avatar
Default Anyone Having Problems with Hawkeye 300
Originally posted by: powerslider
Originally posted by: ranchrocket
the rear subframe is strong enough,,these guys thats gripe and break stuff are just way to hard on the hawkeyes they buy them, and then go jumping and mudding with them expecting them to be like a military Hummer and take a beating,We have two '06 Haweyes here on the ranch and I assure you that they haven't been "jumped, mudded or treated like a military Hummer". The rear sub-frames have been broken on both of them and shortly thereafter the left rear axle on both of them. The rear sub-frames are built WAY to light and they WON'T stand up to everyday use.
Unfortunately for you I don't think the Hawkeye was intended to be a daily workhorse, more an entry level recreational rider. So by now you've very likely come to the conclusion they are the wrong machine for your applications. What is the normal daily routine you put them through on the ranch, just curious.....
We use them for lots of things, working with livestock, checking pastures, fixing fence, and a lot of other jobs as well. We began using ATVs in 1988 and owned 12 or 13 Kawasaki Bayous (mostly all 300s) during that time. They were good tough machines but we lost our dealer so we converted to Polaris thinking that the Hawkeye would be a good replacement for the old Bayou 300. Needless to say, whe have been disappointed with the Hawkeye. We do have an '05 Sportsman 500 and its been a pretty good machine. I like the size and manuverability of the Hawkeye but it is always in the shop. Good thing I have the extended service contract. BTW, I find it ironic that they call the 300cc ATVs "entry level". It hasn't been that terribly long ago that the 300s were the big machines.
Old Jan 14, 2007 | 09:33 PM
  #72
powerslider's Avatar
The entry level comment is my interpretation of the market they were aiming for with the Hawkeye, it's about as simple a machine to operate as you can get. Power delivery is very docile and it's size makes it easier to operate than the big machines. I wish I had the cure for you, I had the jetting issue where the engine ran sluggish on warm days and I did find a small crack in a weld on the rear arm mount after 1200+ miles (with 25" radial tires) which the dealer supplied me the 07 subframe for free. I've had good luck so far and am very happy with it, I picked up an 07 a month ago. They have made many changes to the 07's so maybe all those issues are in the past now, time will tell....
Old Jan 14, 2007 | 09:46 PM
  #73
I'll have to look into the '07 rear sub-frame. I do like the Hawkeye but it has caused me a lot of grief. The big Sportsman steers so much harder that I can really tell when I've been riding it as opposed to the Hawkeye at the end of the day. Also the smaller physical size of the Hawkeye makes a big difference when you get on and off of a 4-wheeler a million times a day.
Old Jan 14, 2007 | 10:02 PM
  #74
Rickeyparker's Avatar
do you Pull anything Like trailers or Boats or stretch fence with the hawkeyes ?
Old Jan 14, 2007 | 10:35 PM
  #75
No towing to speak of. I did pull the calf sled a couple of times. I will admit that our every day use is probably tests an ATV more than folks that just go out riding on the week ends. We also put quite a few miles on them. 1700 miles on the Hawkeyes, 2300 miles on the Sportsman, plus unknown mileage on two Kawasaki machines. I had a two year old "ranch used" Sportsman 600 as a loaner last summer and that crazy thing had 10,000 miles on it already.
Old Jan 14, 2007 | 11:35 PM
  #76
Today in the ice storm i helped a couple get their Mini Van unstuck he wanted me to hook up and try to pull him out with the hawkeye, I looked under his bumper and couldnt find a place to hook up,,he asked me to give him a ride down to his house and get a shovel,,he planted his big 250 behind behind on my Hawkeyes rear rack the ole hawkeye wasnt gonna have it either and All i could think about when he did it is the Atv connection forum Post with sub frame comments and broken a-arms I asked him to get off cause the tires were rubbing,,they werent rubbing but i had this Picture in my head of the hawkeye Limping home with the axle snapped in half and an A arm dangling around..he got unstuck though after i Drove his mini van out of the little ice hole he was in ..
Old Jan 15, 2007 | 02:35 PM
  #77
ArmyHawkeye's Avatar
OK. I just noticed that the Hawkeyes have only one brake in the rear on the left side. I guess because the diff is locked anyway??
Old Aug 3, 2007 | 01:09 AM
  #78
Velocibiker's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ArmyHawkeye
OK. I just noticed that the Hawkeyes have only one brake in the rear on the left side. I guess because the diff is locked anyway??</end quote></div>
Not neccessarily. 4 wheel disk brakes on a light machine would be EXTREME overkill. 3 disks is already overkill. The thing stops amazingly well. Remember, most of you braking force is in the front anyway.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
