radiator additive
Old Aug 13, 2006 | 11:05 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default radiator additive
has any one use these products to bring the temp down. i've heard and going to do a little research on these products. the kind i want is the one you can add w/ the antifreeze to drop temps about 30 to 50 degrees. what kind of luck to you all have w/ these products if any thanks.
Old Aug 13, 2006 | 01:39 PM
Doctorturbo's Avatar
GOT BOOST!
They work.
Not to the tune of 50 degrees, but they do work. If you want a little leeway before you overheat, it will give you this. If you want this stuff to replace a plugged radiator or bad cooling sysetm your going to be disappointed.
Old Aug 13, 2006 | 01:46 PM
v2rider's Avatar
Engine ice does reduce by UP to 50 degrees. Its also safe all year round, down to below like 30 degrees freezing. Its a little spendy, but its worth it. I ordered mine, and you just drain your radiator, and replace it with Engine Ice radiator fluid.
Old Aug 13, 2006 | 08:56 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i want it to work for - 30 degrees or somewhere near just in case and dont want to drain my system every year. i emailed one company called dei radiator relief to ask these tec questions. i'll let you know.
Old Aug 13, 2006 | 09:00 PM
v2rider's Avatar
Liquid Performance Racing Coolant lowers by about 25 degrees, a little less than Engine Ice, but its good at a lower subzero temp than Engine Ice. Its what i use right now, and in Minnesota, it gets pretty cold! I havnt had a problem yet, but im switching to Engine Ice because i want a cooler summer ride
Old Aug 13, 2006 | 09:21 PM
scramblered's Avatar
all those stuff:water wetter (red line) engine ice,royal purple ice,all those additive work great but ONLY during very high heat temp range,i suggest you to get very good quality coolant like maxima coolanol or the best is motul motocool for factory line radiator,very high boiling point and help alot to reduce engine heat and is able to run down
to -35 celcius degree,no need to add any aaditive,,i even remember polaris warned owners to not use those additive in sleds so in the quads it should be the same ways...
Old Aug 13, 2006 | 10:27 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
maybe i need to add a temp gauge to moniter actuall number temps. then we can judge the numbers.
Old Aug 16, 2006 | 10:10 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
well dei company sent me some info on there product saying that it works w/ any type of colant and it does not effect how cold it will withstand temps. thats the main thing for me i dont want to have to drain it or freeze the block.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
Johnny Mac
Aug 15, 2019 03:13 PM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
