1998 Magnum 4x4 Override & 4wd not working
The switch does go bad in the shifter.I would check the bulb in the 4x4 swich first because if it is blowen 4x4 wont work.On your reverse limiter are you sure it hasnt been disconnected.When they go bad most just unplug the black wire and forget about having a button to backup just hold it in for 4x4 in reverse.
