what type of engine oil to use in 500ho motor??
Old Aug 20, 2006 | 05:37 PM
bongload's Avatar
Default what type of engine oil to use in 500ho motor??
Hi
I was wondering what type of oil [weight etc..] is recommended to be used in the motor in my 2000 Scrambler 500ho.
Thanks alot!
Old Aug 20, 2006 | 06:04 PM
cornbread2's Avatar
Use a good quality name brand synthetic oil.
I use and highly reccomend Castrol Syntec 5w50.
And don't let anyone convince you the Polaris oil is better because it is NOT.
Old Aug 20, 2006 | 10:16 PM
ncriderforks's Avatar
Cornbread2, with all do respect and for sake of a good debate, how can you say another brand of oil is better than Polaris? The engine needs a 0/40 weight oil cause of bearing clearance. Not saying a 50 weight oil would hurt over short period but could be bad over time. The 0 weight oil being the hot temp oil thickness is critical. Something too thick can also cause engine damage over time. For no more difference in the price and the fact that it only takes a couple of quarts, just use factory oil if availible in your area and if not atleast get a 0/40 synthetic oil.
Old Aug 20, 2006 | 11:23 PM
cskidmore's Avatar
I am using Mobil 1 full synthetci 0W40 in a couple of 500 EFIs with no issues yet. I looked at the various ratings to insure that it met or exceeded what Polaris recommends/requires in the owners manual.
You likely can't go wrong using the Polaris oil but I also don't think you can go wrong with some of the good synthetics (AmsOil, Royal Purple, Mobil 1, to name a few) as long as you use the proper weight and viscosity.
Good luck,
chad
Old Aug 20, 2006 | 11:40 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
I use Amsoil 0w40 syn. .....My polaris calls for 0w40 syn......caper.....
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 10, 2015 04:54 PM
MNatv89
Jul 7, 2015 11:36 AM
bikedad3
Jul 2, 2015 02:15 AM
