Help with fluid changes 2001 Sportsman 500
Old Aug 21, 2006 | 01:21 AM
brushy's Avatar
Default Help with fluid changes 2001 Sportsman 500
I have a 2001 or 2000 Sportsman 500. I have had it serviced at the dealer a few times for oil changes, etc... and wanted to start doing the job myself. My aftermarket mannual calls for the following and I wanted some help with what brand / weight to pick up at my local discount store.
1. Engine Oil: Calls for 10W/40 Synthetic....I already purchased Mobile 1 10W/40
2. Filter: I purchased Fram 6017A
3. Transmission: Calls for Synthetic Gearcase Oil ??? Only thing I saw at Wal-Mart was a bottle of Super Tec Synthetic (32oz) Gear Lubricant ???
4. Front Gear Case: 3.25 oz of API GL5 80-90 Gear Lube....I believe I saw this in the Super Tec also and a product from Shell
5. Coolant : 50/50 like Prestone?
Let me know if #1,#2 are ok since I've already purchased...I can always take them back if needed.
Any help or suggestions of brands and exactly what the bottles say on them for #3,#4 and #5 would be appreciated.
I just use the 4 wheeler for basic riding and almost always at medium or low speeds.....dirt roads with the family and hunting is about it.
Thanks,
Old Aug 21, 2006 | 01:49 AM
sheepdogMSP8117's Avatar
As far as the engine oil, Mobil 1 is fine. Sorry I can't advise you on the others but I'm sure you'll get someone else to answer soon.
Old Aug 21, 2006 | 10:40 AM
Kerbbirds's Avatar
Hello, you can use mobile one in the tranny too, I use Castrol Syntec in my engines and tranny's, have for a long time, havent had any problems. The front diff on the 500 takes 80-90, I use Castrol Synthetic in mine. You can use ATF in the front hubs, but I think the hub drive fluid from polaris works better, they seem to disengage better with it. AS for anti-freeze they say to use distilled water with 50-5mix.
Old Aug 22, 2006 | 10:14 AM
brushy's Avatar
So go ahead and use Mobil 1 10W/40 in the transmission?
Thanks,
Brian
Cole Hadden
Jun 15, 2025 09:05 AM
robert301972robert
Aug 30, 2015 11:34 AM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
Sandman2.0
Jul 21, 2015 09:03 AM
rcappie4
Jul 10, 2015 04:54 PM
