found oil in air filter cover?
Old Aug 22, 2006 | 12:26 PM
brownweiser's Avatar
Default found oil in air filter cover?
i have a 2000 sportsman 500. i was driving it up and down my ramps to test them out. i checked the air filter and found a small amount of oil in the bottom of the cover? is this a problem or is it a normal occurance when these things are on a steep incline??
thanks
Old Aug 23, 2006 | 02:36 AM
jimmypsp700's Avatar
Thats normal.
If you stand most polaris' on end including the pred it will leak back into the air box.
Also some blow-by from the breather is normal or if its overfilled with oil it will happen more.
Jim
Old Aug 29, 2006 | 12:00 AM
Grizzflogger's Avatar
My son overfilled his predator because he did not read his manual closely for proper checking with dipstick. Lots of oil bled out into air box for about two trips then was fine. It was not stood on end, just too full!
Old Aug 29, 2006 | 11:35 AM
thanks guys. didnt think it was a big deal
Old Aug 29, 2006 | 04:37 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if its at the right level of oil in it and your riding fairly normal just check to make sure its not an on going problem maybe blow back form the crank having too much pressure building up. chances are your fine. just keep checking once in awhile.
lightninboy
May 16, 2021 09:52 PM
Captjay
Jul 23, 2015 12:33 PM
cSchwartz
Jul 9, 2015 02:43 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
