03 Sportsman 700 Carb - acceleration Probs
I've had relatively good luck with my first year model 2002 Sportsman 700 and am very happy with it.
I have replaced the carb boot/adaptor (before it cracked thru). Check that, the rubber gets weathered/dry rotted bad on some and may crack through.
And the hall speedo sensors sometimes go out ($50 part, p/n 4010298), its at the right front wheel rotor and has a wire going up to the pod.
Also the water pump cover should be a metal replacement of the leaky original plastic cover.
This was a Tech Service Bulletin for early models in '02 and some '03's.
The crank breather should be omitted for colder climates, this was also a Tech Service Bulletin (TSB).
The TSB is #S-03-05 and the part # is 2202744
Also some machines, mostly '03's have cold weather start jetting updates, both of the TSB's and the jetting should have been taken care of under warranty.
Jim
Jim
bzdok1234
30
02-23-2016 01:55 PM
