Oil gauge on 500HO
Oil gauge on 500HO
I haven't installed it yet. I have the parts and installed everthing to make sure. I will be putting in a T connector where the current temp sensor is installed. Bought a 3/8 T and other various parts to make everything fit. The oil connection is a different story. I have no idea where or if I can plug into an existing hole.
Oil gauge on 500HO
good luck!!!
Oil gauge on 500HO
I know there is an oil plug behing the primary clutch cover on the 700 and that's where I put mine. I happens to be just below the t-stat housing. I had to cut down a std allen wrench to get in and back the plug out and put a 90* fitting in to get the pressure sender in. Word to the wise. Don't use a capalary system. Tpay for an eletric sender. Less places to get an oil leak. From there it's a peice of cake. I would assume that in the service manual there is a description of an oil pressure check port. That's where you want to tap in for oil pressure. As for the Temp sensor. Just pull your t-stat cover and drill and tap it. It will eliminate the need to mess with the stock fan sensor port.
Oil gauge on 500HO
Thanks for the responses. I'll take a look for the plugs that are mentionned. There's a few guys on other forums that have installed these gauges but they are on 700's. I haven't seen any pictures of installs on a 500. If anyone finds any I'd like to see them. The gauges mount right into the pod but you have to get 1.5" gauges.
Logan Collins
09-05-2015 08:03 PM
bradco
08-21-2015 08:11 PM
