Grease fittings on polaris
If you grease them as you should, they will last & last. Don't like to grease, the sealed ones will go farther.
My dad has an old car with 210,000 miles. The u-joints have been replaced once - to the greasable kind at about 50,000 miles. Also, the one steering joint without a zerk is the only one that wore out so far. We give every zerk a shot or two every 2500 miles (with oil change). The trick is to grease often enough to keep it lubed, but not so much to blow the seals.
John Boy
07-13-2015 11:16 AM
ranvette
07-04-2015 06:13 PM
