HELP-->Wrecked!-->Broke!!!
Old Oct 2, 2006 | 08:14 PM
la90043's Avatar
Default HELP-->Wrecked!-->Broke!!!
circuit breaker is usually the push button type........when tripped it'll be popped out.................to reset circuit breaker "push" in...................where's it at................i dont know..............but if manual says to reset it...................well then go ahead and reset when you find it...........
Old Oct 2, 2006 | 08:29 PM
bombaman's Avatar
That's just it...I can't find it. Called dealer and they weren't sure either. Thought it was on the fire wall but I don't see anything.
Old Oct 2, 2006 | 11:15 PM
la90043's Avatar
i couldnt find a circuit breaker in the parts catalog to your atv
this parts catalog is to an 2005 sp 500 Ho...........couldnt find a parts catalog for the 06..........but they the same probably.....................look through the parts catalog....the handle bar headlight assembly with all its switches.......and then the electrical assembly with the stator...cdi..........coil...........selenoid..... .........couldnt find no circuit breaker switch part...............look for yourself.......................give it a clicky here to review handlebar assembly with the switches and all then go to other electrical to the stator, cdi etc etc etc
Old Oct 2, 2006 | 11:35 PM
la90043's Avatar
put in 2005 for year..they dont have the 2006...........but it'll be the same...........then do a visual search for a circuit breaker........i doulnt find one no where on the parts diagrams and listings............
clicky here
Old Oct 3, 2006 | 12:06 AM
  #15
bombaman's Avatar
I took the switch apart and found it was missing some pieces inside so I'll buy a new one and see what happens.
I also noted what appears to be a broken wire. I'll try and post a pic of it in the gallery.
Does anyone know if the top of the firewall where the top mount of the steering column is supposed to be a U shape? I can't tell if it's bent or just shaped that way. How far away is the column from the gas tank...that would answer it.
Old Oct 3, 2006 | 12:10 AM
  #16
la90043's Avatar
the steering stem...................post can bend.....................do the handle bars hit the gas tank huh when either you turn left and or right.........?
Old Oct 3, 2006 | 12:22 AM
  #17
bombaman's Avatar
No the stem looks straight and it doesn't hit anything. However the brace for the top of the stem is against the tank...maybe it should be...
The top of frame where the stem attaches is what I'm wondering about. Looking down at the frame piece its shaped like a U with stem in the middle...the open end is toward the front. I guess I wonder if it should be a U or a __.
The U shape is exaggerated but still it could started like this __ and the stem pushed it to U. This symbol better describes it "(" open end toward front.
Old Oct 3, 2006 | 12:28 AM
  #18
la90043's Avatar
if the atv turns with ease as before and the handle bars did not take a beating and get bent out of shape........probably the steering stem post assembly is fine........and yes the "u" shape stem bracket should be fine too...........get that new switch and you'll be ready for another crash and burn soon.........![img]i/expressions/face-icon-small-cool.gif[/img] just kiddin............they're aweful huh........!
Old Oct 3, 2006 | 12:36 AM
  #19
bombaman's Avatar
I'm disappointed that the pod is so easily broken. Granted it works better when running on the tires and not the handlebars.
Is there a wiring diagram on the web somewhere???
Old Oct 3, 2006 | 12:54 AM
  #20
Lukester's Avatar
Yeah, thought the same thing too. That is, the thing should roll over and not brake the pod. At least if it was designed for that real possibility it shouldn't.
