Sportsman 90 no spark bad stator?
Old Sep 30, 2006 | 11:08 PM
lukesquad's Avatar
Default Sportsman 90 no spark bad stator?
Hi, My son ran his 2001 polaris sportsman 90 thru about 2ft. of water and I had to replace the stator ($141.00) I put the stator in today it started up great 4 or 5 times. Took it around the house 1 time and now no spark again. My question is should I replace something else or do I have something that blew this new stator up. Is there a way to check the stator or the CDI? Thanks, Any help would be nice.
Old Sep 30, 2006 | 11:37 PM
la90043's Avatar
the rubber boot that fits over the spark plug...............unscrew or pull it off the spark plug wire and snip about 3/16 off each end of the wire...........they corrode at the ends and create a weak spark or no spark to the spark plug.............some wire screw off the rubber boot buy turning the wire off just like a nut or screw............(twist off)....................after snipping each end a bit.......twist back on...........screw the spark plug wire back into the boot.................the spark plug wire can also be corroded throughout the whole wire too.................if so go to your nearest friendly neighborhood auto parts store and get a new wire..........................
Old Sep 30, 2006 | 11:46 PM
lukesquad's Avatar
I should have said it has a new coil and wire assemlby ($45.00) that was before the stator.
Old Sep 30, 2006 | 11:52 PM
la90043's Avatar
dead battery...........?weak battery?...............loose battery connections?................corroded battery terminals?..............loose selonoid terminals..................?
Old Sep 30, 2006 | 11:54 PM
la90043's Avatar
does it have a circuit breaker...................and or fuse.............?
Old Sep 30, 2006 | 11:57 PM
la90043's Avatar
run switch on the "on" position huh..............?..........................lol... .................!..........you never know............!!!!
Old Sep 30, 2006 | 11:58 PM
lukesquad's Avatar
Battery good. It turns over good. I was either grounding out the plug to see spark or I would stick a screwdriver in plug cap to feel spark. Dont get spark either way. The fuse at the battery is good.
Old Oct 1, 2006 | 12:00 AM
lukesquad's Avatar
All switches check out, break switch, pull cord kill switch, on/off switch
Old Oct 1, 2006 | 12:04 AM
la90043's Avatar
on off run switch any good...........? can you jump the swtch.........? bypass it huh.........?
Old Oct 1, 2006 | 12:07 AM
la90043's Avatar
can you open the run off switch and inspect for good contacts huh......?
