sportsman 500 electrical problem HELP
Old Oct 9, 2006 | 01:45 PM
DLR67GUN's Avatar
Default sportsman 500 electrical problem HELP
I have a problem with a 1999 500 Sportsman 500. The headlights and speedometer dim every so often. Also the high beam burnt out yesterday the low beam bulbs burnt out. I have replaced the voltage regulater and put a new battery in it. Can any one give advice?
Old Oct 9, 2006 | 01:54 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
well since you said they dim , i would guess a bad ground some where. if its the regulater usally it will be too much power making the lights extremly bright just before they blow.if you put a tester on the battery w/ the bike off and put the lights on it shouldnt drop too much and be around 11.8 to 12.5 volts. w/ the bike running it should be 13 to 14.5 volts.
Old Oct 9, 2006 | 02:06 PM
DLR67GUN's Avatar
Thanks for answering. when I rev up the engine the lights got brighter as the engine got warmer they got even brighter
ripperray
Oct 10, 2023 02:42 AM
skittero
35
Mar 1, 2019 12:39 AM
Raccar1
Jun 18, 2015 02:17 AM
DOAinNY
Jun 11, 2015 10:34 PM
