recoil problem
Old Oct 12, 2006 | 07:22 PM
jammerfri's Avatar
Default recoil problem
i have a 93 polaris 350l and i had to take the starter out to replace the brushes....i had to remove the recoil to get at 2 bolts inside and now i cant figure out how to get the darn thing to recoil....i need help...spent all day today on just that and still couldn't figure it out... i have the haynes manual and it says to just spin the recoil 3 complete turns after the cord is tight and then that should set the tension...but it doesn't....its just not generating tension...i am sure its something simple but i cant figure it out....thanx in advance ?..jamie
Old Oct 13, 2006 | 11:06 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like your spring came unhooked. it you pull out the cord and its not recoiling back at all and you have wound it up so to speak then its what i said or it broke one of the two.
Old Oct 13, 2006 | 12:05 PM
jammerfri's Avatar
when you say spring which spring are you referring to????
Old Oct 13, 2006 | 08:15 PM
MoosEye's Avatar
jammerfri
There is a spring behind the reel that the rope winds around. If I remember there is a nut in the center that holds the reel and the spring is coiled behind it. Be very careful as the spring is connected to the reel and the housing and can spring out at you in a hurry when you remove the nut.
Old Oct 13, 2006 | 08:23 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
just a note but if you never done one b4 like he just said it can be dangous w/ the loaded spring. maybe worth taking it to a dealer or someone that has done one.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Desimation2k8
Jul 17, 2015 12:37 AM
