1997 Polaris 400l 4x4 starter
Old Oct 26, 2006 | 12:14 PM
FRANKIEZ's Avatar
Default 1997 Polaris 400l 4x4 starter
What is the easiest way to change starter and any special tools, and how do I check starter bendix/drive for condition when I am in there? Thanks
Old Oct 26, 2006 | 06:56 PM
WIscrambler's Avatar
The easiest way to access the starter is to remove the entire clutch housing to acces the bolts which hold on the starter. You can get to the bolts from underneath, but it is a PITA for the clutch side bolts. You also have to take off the flywheel cover on the other side of the engine to remove a couple bolts near the bendix. When the starter is off, it is a good idea to pull it apart and check the condition of the brushes inside. They commonly go bad after years of use.
Old Oct 27, 2006 | 07:51 AM
FRANKIEZ's Avatar
Thanks for the information.
Reactant
Mar 30, 2022 02:08 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
tweeder
Jul 5, 2015 01:57 PM
