Sportsman 800 Whining clutch
I've seen a post about this same problem before , about 2 or 3 week's ago i think it had a few reply's saying it was normal and wound go away after break in ; have you tryed reducing the idle speed ? Just thinking out loud , i have a 06' AC 400 Auto fis with the suzuki belt driven clutch with only 197 miles and 2 oil change and service , but only does it when i first start it up when cold in gear it whine's a little untill warm up . Doesn't do it when engine is warm or in newtral ; only when cold in gear untill warm up and rpm's reach 1450 to 1500 then whine goes away ! .......................williebee
Roadstar it's still under warrantee right ? I would take it back to the dealer and tell them to fix it , or give me a new quad ; or at lest a loaner to ride untill they fix your ! I wouldn't wait anylonger and take a chanch it break's down on me out in the middle of nowhere and leave's you stranded ! If you wait to long and the clutch or belt get's smoked , polaris may say it's your faut for waitng to long knowing there was something wrong ! I've heard other's say that polaris has a lifetime warrantee on the belt's , at least a friend of mine had a 93' ploaris sportsman 500 thant his dealer replaced a belt on his in the summer of 2000 free of charge ! .................................hope you get it fixed i know how it feel's when you're left afoot ! ........................williebee
