03 700 plug foul?
Old Nov 20, 2006 | 08:44 PM
SAshton's Avatar
Default 03 700 plug foul?
I rode yesterday in tight trails. very slow. I started my bike today and had the choke out for like 2 -3 minutes and when I went to go it bogged and I checked the plug and they are black.(not oil fouled) Will the choke out run it that rich to foul the flugs? Anyone else foul a plug?
Old Nov 20, 2006 | 08:52 PM
SPORTSMAN70003's Avatar
If its a little rich on the pilot screw and you had the choke out for a while yes that could foul your plug. I would suggest going back with NGK plugs.
Old Nov 20, 2006 | 10:58 PM
SAshton's Avatar
I do have NGK BKR7ES
Old Nov 21, 2006 | 12:39 AM
Doctorturbo's Avatar
GOT BOOST!
The way to use a choke is like this:
If it's cold out just pull the choke out enough to light the engine. Once lit, push the choke in slowly and see if it idles. You will be able to tell when it's going to die. When it tries too, just leave it sit a little longer idling on the choke. Only use enough choke to light the engine.
Too much choke will wash down the cylinders and fould plugs and this is never a good thing.
Old Nov 21, 2006 | 06:30 AM
Speeddrive1's Avatar
I have the same wheeler and had a problem with the choke plunger not returning all the way. The plunger gets corroded up and wont slide back and forth. I doubt it is the way you are using the choke if you have had this wheeler for awhile and never had a problem before.
Old Nov 21, 2006 | 08:06 AM
SAshton's Avatar
I left the choke on and walked away for a couple minutes.(All my other bikes I left the choke on until it warmed up but I guess Polaris will be different.)
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
cornermike
Jul 30, 2015 06:37 AM
Captjay
Jul 23, 2015 12:33 PM
